Dear Chaosgroup,
When working with V-Ray latest nightlies build in Cinema 4D S24 also on R23 I have big problems working with Materials in the viewport. I have to turn of material preview in the Viewport so I can actually work, because taskmanager shows one CPU thread continously at 100% and networkusage at about 1 Mbit the second.
My textures are in a network saved. So preview is often never be updated, Cinema is horrendous slow because of continously CPU Usage for nothing and I cant Work anymore.
When using the same textures in a Standard Cinema 4D Material Cinema viewport works fine. It loads the Texture at 100 Mbit over network and its loaded fast and fine.
In my opinion two things have to be fixed as soon as possible to get even work with Vray 5 that is:
- Renderinstances makes Vray unusable because the more you have the longer (and I mean LONGER) vray needs to even start the render. This is horrible
- Materialpreview, what I mentioned above
I mean this in my opinion are ESSENTIAL parts of Vray to work. If These two things get fixed, I can finally Work with Vray 5. Currently I also do but its a pain in the a**
@shaio: I know theres a problem with C4D prioritizing material preview over anything else and all the rest of it but this must be fixed soon. Especially the renderinstance problem. I cant render animations like this or make testrenderings. Because i have to wait minutes before Vray decides to start. Is there any kind of coding progress?
Edit: I post a scene and a video later
Thx in advance
Greets PdZ
Thx in advance
Greets PdZ
