V-Ray Output System Multi Frame Render Bug
  • V-Ray Output System Multi Frame Render Bug
    If you choose a frame rate in Output > Frame Rate that is anything other than Project Frame Rate. V-Ray Output System will not output any rendered frames. Render continues to run w'out any errors / warnings. However, the files will not be saved.
    In my case I have used Distributed Rendering option with 'ignore local' enabled.
    Hello imdb,
    Upon testing on my end I didn't face any issues when using the V-Ray Output system with FPS in Project settings set to 30 and Frame rate in the Output settings set to 25. I tried rendering both locally and with Distributed Rendering and every time I had my output saved in the desired directory. Can you please share more information about your setup, such as exact V-Ray and C4D versions, OS version, are you using V-Ray or V-Ray GPU. Also, if possible, please share the scene in question so we can have a look. Thank you.
    Aleksandar Kasabov
    chaos.com
