Using ply2vrmesh tool to convert an Alembic (abc) file with velocity data, results in a small vrmesh file.
Converting a regular abc file seems to work without any issues. It fails when velocity data is present.
Here's the output I get no matter what parameters I pass.
test8.abc is 2.7 gigs. I'd attach it here otherwise.
test8.vrmesh.zip
Coincidently. If you attempt to use this test8.vrmesh using VRAY Proxy. Cinema 4D crashes.
_BugReport.zip
test8.vrmesh.zip
_BugReport.zip
