viewport: black textures with layers
  • viewport: black textures with layers
    Hi everyone,
    I installed the latest build (v5.10.22) and having trouble with the preview of textures if I use layers.
    Using a bitmap in the diffuse channel is just fine but after putting it into layers I'm seeing black objects.
    I cannot work this way! All my scenes are black!
    Do you have a solution?
    shaio
    Hi klex167, I confirm that this do not work right now, you can use a Vray layered shader or insert the C4D layer inside a C4D bake shader, then it will work
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      Hey
      I have kind of the same problem. Textures are missing in the viewport, just black. Found out that the problem apears when using Filter with Gradiation Curve Enabled on the texture. When Disabling the Graduation Curve the texture shows up again in the viewport.
        Originally posted by patrik_beck View Post
        Hey
        Same solution, use a C4DBake shader, in alternative you can grade your texture using the remap shader available on the node editor:
Name:	Schermata 2021-09-06 alle 10.48.14.png
ID:	1124046Click image for larger version
Name:	Schermata 2021-09-06 alle 10.52.31.png
          Of course those are only workarounds, texture preview should be fixed
            Hello and thank you for your reports.
            I managed to reproduce this issue and I logged it in our internal bug tracking system (VC4D-1083) for fixing. I will let you know once we have more information. Until then, you could use the workaround that sirio76 mentioned and load the texture inside VRayC4DBake shader. Thank you.
            Aleksandar Kasabov
            chaos.com
              Thank you guys!
                Hi everyone,
                This issue was fixed and you can find the fix in our latest stable build. You can download it and install it from here:
                https://nightlies.chaosgroup.com/mai...table/20210915
                Aleksandar Kasabov
                chaos.com
                  Thank you Aleksandar! This was very important.
