I'm currently evaluating V-Ray again and especially the node editor support. It's seems promising but it still lacks few key features in my opinion.
The most obvious use case is to have the ability to mount PBR materials made up of bitmaps sharing the same projection but not being limited to it's mapping for layering dirt / decals textures.
Furthermore, there is a strong lag when connecting and disconnecting nodes, about half a second, which is a bit annoying during lookdev. In CPU and GPU mode, even when IR is not running.
Also solo isn't supported, which would not be a big deal if there wasn't the aforementioned lag happening everytime a map is plugged in diffuse channel to check the look.
I guess you are aware of these limitations and are working to improve the plugin, but I wanted to make sure you were aware of it
- I can't override Material Tag level mapping
- I can't set a specific UVW projection or UV Set per bitmap ( like with Map Channel in 3dsMax )
- I can't share a specific UVW projection between multiple bitmaps
- I can't transform UVW coordinates, which would be useful for specific bitmap projection, but more importantly for transforming UVW coordinates of a specific set of bitmaps while retaining Material Tag projection settings.
- Triplanar still requires the bitmap as an input whereas it should be the other way around : Triplanar with an output in a UVW input in the bitmap node. Thus the projection could be shared among several bitmap nodes.
