2Sided Material causes crashes
  • 2Sided Material causes crashes
    Hi guys,
    when I want to sort a 2Sided Material in the material manager and want to change the order, vray crashes
    with kind regards
    Jörg Schönebeck
    C4D R21, Vray 5.10.22
    MacPro 6.1
    macOS 10.14.6
    Hello Schoenebeck,
    Could you send us a short video of your screen where you demonstrate the crash? Please provide us with a spindump file from the crash. You can find instructions on how to collect this here.
    Also, could you check if you have a similar directory in your user directory and send the bug report files inside?
    Code:
    ./Library/Preferences/MAXON/Maxon Cinema 4D <version>/_bugreports
    where <version> is your Cinema 4D version followed by additional characters. For example, the full directory would be something like:
    Code:
    /Users/username/Library/Preferences/MAXON/Maxon Cinema 4D R21_2FE1299C/_bugreports
    Thank you.
    Aleksandar Kasabov
    chaos.com
      Hello Aleksandar,
      i attached the bug report.
      I already had a strange behavior under 3.7. Especially if in the parameters of the front and back materials that had been assigned were not found due to missing links.
      Best regards
      Jörg Schönebeck
        Hello Schoenebeck,
        The bug report doesn't seem to provide us with enough information to understand the reason for this crash. Please send us a spindump file from the crash so we can have a look at it. In my previous post, I sent you a link to an article where you can check how to collect the file. Thanks.
        Aleksandar Kasabov
        chaos.com
