Hello
I am testing C4D, Realflow for C4D and VRay for C4D. I've found a strange behaviour when rendering a sequence with fluids (not with mesh that works well) from Realflow for C4D plugin. It seems like if VRay compiles geometry information of each frame and renders fluid information from all prior frames of the sequence in every frame. For better understanding: If I render frames from 30 to 45, frame 30 is rendered fine; frame 31 is rendered with fluid information from frame 30 and 31; frame 32 with fluid from frames 30, 31, and 32; and so on.... Rendering frames one after one works fine, but rendering a large set of frames isn't operative in this way.
Regards.
Regards.
