VrayNormalMap Shader - Different result with and without UVW Projection Tag
  • VrayNormalMap Shader - Different result with and without UVW Projection Tag
    Hello,
    I am not sure if this is really a mistake or not. But when I am using the VrayNormMap Shader I have different results when rendering the material in UVW Mode with tag or as cubic.
    VrayNormmap Shader with UVW tag looks much stronger and nicer..., but which result is the correct one...?
    Thanks
    Click image for larger version  Name:	Screenshot 2021-10-29 11.00.34.png Views:	0 Size:	491.0 KB ID:	1128672
    Click image for larger version  Name:	Screenshot 2021-10-29 11.00.08.png Views:	0 Size:	464.2 KB ID:	1128673
    I've tested a normal map by simply loading the texture and I get identical results with both cubic and UV projection. By using the normal map shader I get different results and I would say that there is something wrong in there, probably developers needs to check this.
    Unless you have specific reasons to use the normalmap shader use the standard method and remember to set the normal map in linear mode
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      Hi sirio76 , yes I will do so! I have a scene with a lot of VrayNormalMap Shaders and happy with the look! Just wondering, when this will be fixed, if this look will change... Let's see...
      Thanks!
        Hello haniel1107,
        Thank you for your feedback.
        I reported this to our developers (bug ID: VC4D-1144) and I will let you know once we have more information.
        Aleksandar Kasabov
        chaos.com
