Textures are not loaded when changing materials
  • Textures are not loaded when changing materials
    Hello,
    I found a weird behavior in terms of switching materials at a keyframe. Textures files are not loaded when i render the animation in VFB.
    I´m working with the latest Versions of C4D R25.015 and Vray Update 1.4. Is this a known problem? Does anyone has an idea of getting it to work?
    Need some help because it's essential for continue working on my projects...
    Example files:
    c4d-vray-mat-color.c4d - switching materials without textures work
    c4d-vray-mat-texture.c4d - first texture are loaded. 2nd and 3nd appears black
    c4d-vray bitmap-mat-texture.c4d - first texture are loaded. 2nd and 3nd appears white
    Thank you in advance
    Christian
    Hello christian_tremmel,
    Thank you for bringing this to our attention.
    Upon testing it I also managed to reproduce the issue and I reported it to our developers for fixing (bug ID: VC4D-1160). I will update this thread as soon as I have some information to share.
    I noticed that this only happens with V-Ray but it doesn't happen with V-Ray GPU. You can also keyframe and switch the texture instead of the whole material and it will render correctly as well.
    Aleksandar Kasabov
    chaos.com
      Hello aleksandar.kasabov ,
      Thank you for your quick reply and open up a ticket.
      I took your idea of keyframing and switching the textures by python tag and wrote a short test script.
      it works in principle but for some reason sometimes skips the second texture and if all textures are rendered correctly crash Vray after rendering the last frame. I am a little frustrated. Maybe you can look over again. To set all keyframes by hand it´s in my case not possible. I have no experiance with render by GPU. I guess my settings are wrong because it´s super slow und super instable.
      Thank you in advance, Christian
        After testing over and over I got an error message. Maybe helpful:
Name:	Vray error message.JPG
          Are you experience the crash while rendering the c4d-vray-mat-texture-python.c4d scene? Are you using the default V-Ray GPU settings? Also, please specify what are your GPU model and GPU driver that you have installed? Thank you.
          Aleksandar Kasabov
          chaos.com
            Hello aleksandar.kasabov,
            thanks for your quick reply. Yes, of course I went into this crash while rendering the c4d-vray-mat-texture-python.c4d scene.
            Especially at this crash I used the default CPU settings. But the last days I switched to GPU rendering because works best in my case.
            I use the default settings with Buckets - Cuda Engine. (Cryptomatte are supported)
            >>>>What's interesting, first time rendering of the scene everything work perfect, but unfortunately second time crash Vray after finishing rendering without error message.
            Hardware:
            AMD Ryzen Threadripper 2990WX 32-Core
            Nvidia GeForce RTX 2080 Ti - Driver Version Nvidia 30.0.14.9613
              Dear christian_tremmel,
              Thank you for providing those details.
              Upon testing on my end I managed to reproduce the crash and I also reported it to our developers (ID: VC4D-1171). I will let you know once I have any updates on the matter.
              Aleksandar Kasabov
              chaos.com
                thank you for backing me up in this matter.
                I´m looking forward to your reply.
                ​​​​​​​cheers Christian
