VrayObjectProperties
  • VrayObjectProperties
    Is it possible that VrayObjectProperties do not work on objects with selection in GPU rendering?
    Hallo,
    Kann es sein, dass VrayObjectProperties auf Objekten mit Selektion im GPU-Rendering nicht funktionieren?
    Click image for larger version  Name:	Bildschirmfoto 2021-12-12 um 11.14.56.png Views:	0 Size:	11.0 KB ID:	1133767
    Click image for larger version  Name:	Bildschirmfoto 2021-12-12 um 11.18.56.png Views:	0 Size:	442.8 KB ID:	1133768
    macOS Catalina, Cinema 4D R21, Vray 5.20.00 from Dec. 8 2021
    Best regards
    uwe
    Dear pardalis,
    Upon testing this on my end I couldn't reproduce the issue. Have you simply added a VRayObjectProperties tag? Have you by any chance enabled the Matte Surface option in the Matte Properties tab? Would you mind sharing a test scene where the issue is reproducible so I can have a look? Also, you mentioned that this issue happens when rendering with V-Ray GPU but you also mentioned that you are using macOS. As GPU rendering is not supported on macOS, could you please elaborate more on that part? Thank you.
    Aleksandar Kasabov
    chaos.com
      Hello pardalis,
      Apologies for my previous post. Upon testing this again I managed to reproduce this issue. It seems like a bug on our end and I have reported it to our devs for fixing (bug ID: VC4D-1203). I will keep you updated on its progress. Thank you.
      Aleksandar Kasabov
      chaos.com
