depth of field with DR
  • depth of field with DR
    I'm wondering if I'm missing something:
    Rendering DOF via DR works only in the first frame. See the pictures:
    1st frame works
Name:	dof test0001.jpg
    2nd frame is wrong
Name:	dof test0002.jpg
    Scene attached (latest build). Thanks for a tipp - klex
    Dear klex167,
    This is a known issue that has previously been reported in this thread. It has already been reported to our developers (bug ID: VC4D-915).
    The current workaround is to activate the Depth of Field both in the V-Ray Physical Camera tag and in the Camera rollout in the Overrides tab of the render settings. This way you will ensure that the depth of field is rendered correctly both locally and on your server machines.
    I will let you know once we have more information on the matter. Thanks.
    Aleksandar Kasabov
    chaos.com
      Hi Aleksandar,
      thank you for the quick answer. Its working this way!
      Great!
