mirror image
  • mirror image
    The tex is displayed in a mirror image.
    How to correct this?
    How about this?
    It's a workaround, but should do the trick for most use-cases
    Click image for larger version  Name:	Cinema_4D_f1Sv16yXJs.png Views:	0 Size:	248.7 KB ID:	1138783
    I saw you have the texture in a VrayBitmap, you can also flip it in there. Just tile it in UV and set the Width to -1.
      Thank you.
      Yes that's true, but shouldn't it be correct by default?
        Originally posted by Makushimu View Post
        Thank you.
        It is correct, it's just that you point the light upside down on a plane so it's like if you see it in a mirror:
        Click image for larger version  Name:	Schermata 2022-02-03 alle 10.40.57.png Views:	0 Size:	343.6 KB ID:	1138807
        3D Scenes, Shaders and Courses for V-ray and Corona
        NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
        @3drenderandbeyond on social media @3DRnB Twitter
