Shaders inside vraybitmap not relinking in c4d
  • Shaders inside vraybitmap not relinking in c4d
    Hello,
    I've downloaded a free sample from the producer maxtree.org and I'm trying to open it with c4d R25 and vray 5 on a mac os
    When I open the file, the link of the textures are missing, which is normal. I relink them through the project asset inspector and the path is working. the problem is that all the shaders are inside a vray bitmap, which keeps the same directory created by the developer. Of course i can manually find the shader, but as you can imagine, do this tedious work for all the channels is a no go. Is there a way to solve it?
    Hello nadia_cristelodias,
    This seems to be a Cinema4D issue and not related to V-Ray. Upon testing, I managed to reproduce the issue with the native C4D loader on a Standard C4D material (Renderer set to Standard). Please check this screenshot. It even happens if V-Ray is completely uninstalled. You can contact Maxon for further assistance with that.
    Aleksandar Kasabov
    chaos.com
