UVW Randomizer in Vray5.2.3 crash's when using stochastic tiling
  • UVW Randomizer in Vray5.2.3 crash's when using stochastic tiling
    Hello, I have a problem when I am using the UVW randomizer. I create a new material, select the UVW Ran. in the diffuse channel, click into the randomizer, set a picture into the texture channel, switch to stochastic Tiling and like to go back, then Cinema crash's. Always... ? Using Win 10 R25 latest Vray... Do you have an idea what's wrong? Thanks in advance...
    Hello haniel1107,
    I regret to hear that you experience those issues.
    I followed your steps but was not able to reproduce the crash on my end. Would you mind recording a short video, demonstrating the crash and sending it to us? Also, can you go to the _bugreports folder in your preferences folder and send us the files if there are any? Can you generate a crash dump file and send it to us as well? You can find the steps on how to do that here.
    Lastly, are you using the latest official V-Ray build or do you have the latest stable build installed? Thank you.
    Aleksandar Kasabov
    chaos.com
      Hello aleksandar.kasabov thanks for your reply and testing it out. I am right now rendering something, but then I will try to reproduce it with a short video..
      And yes the latest build... Thanks
