C4D S26 Cloth simulation won't render animations
  • C4D S26 Cloth simulation won't render animations
    I've got the new C4D S26 and made an animation using the new cloth engine and it renders 1 frame, but if I render an animation it only renders the first frame of the animation and keeps on doing so for the rest of the frames.
    I've tried rendering with the cloth sim baked and not baked, both won't work. Is there an option I have to check to make it work, or is it just not supported by V-ray?
    Hi boudewijn_berends, we had other reports for the animation problems with the new cloth simulation in S26 and are currently investigating the issue. We will write when we have more information on the subject.
    Deyan Hadzhiev
    Developer
    chaos.com
      Thanks deyan.hadzhiev for your quick response, do you know if there is a workaround for this problem? I've got a perfect cloth animation and put a lot of effort in small subtle details. It would be a bummer to do it all again in the old cloth engine. I don't even know if I can get it ever done with the old engine.
        hi boudewijn_berends
        baking the sim as an alembic cache seems to render fine on my side, maybe give that a shot as a temporary workaround
