C4d to Vantage
  • C4d to Vantage
    I have the problem when I create a project in Cinema and output a Vray Scene, then open it in Vatage, everything works normally, but when I add a Camera to my stage objects and pass it back to vr.scene, the cameras and frames are opened in Vantage not updated.
    I have to output the vr.scene under a different name then it works.
    And a problem with light sources that are in a group, which cannot be controlled properly either, on and off, now the question arises where is the error in C4D or Vantage?
    Hello Wohnraumdesign
    Please be informed that we only provide support in English.
    Can I kindly ask you to write your questions in English, and we will assist you further?
    Valentin Leondiev | chaos.com
      Sorry
        Thank you for reaching out to use about this issue!
        Would it be possible to provide a bit more information regarding the issue, so we can better help.
        1: Would you be able to provide a screen recording of the issue occurring with all steps leading to it?
        2: Can you please provide an example scene of the setup that we can test with and replicate the issue? You can use any file sharing platform and provide us with a download link. If you don't want to share the scene publicly, you can message me directly or open a ticket via the Request Form.
        3: Can you please share the exact Vantage, Cinema 4D and V-Ray for Cinema 4D Version you are using?
        3.1:You can find the exact version of V-Ray at V-Ray dropdown > Help > About > Right click text and select the copy text option and paste the information here.
        Example: V-Ray 5 for Cinema 4D, Update 2.2 (v5.20.02 from Feb 21 2022)
          I have sent you the scene and the data via the support form
