Add / Remove Button for layers in Layer Node
  • Add / Remove Button for layers in Layer Node
    Hi, not my biggest wish on my wish list, but getting back the add and remove buttons for layers in layer node would be great. Like in the documentation.
    For now right mouse click and add layer is doing the job, but how deleting a layer? (Except unchecking enable box)
    Hope it make sense... Thanks
Name:	Screenshot 2022-06-15 18.26.28.jpg
    Documentation:
    What version are you using (Vray/C4D)? Here it works (R25, Vray build early June, MacOS)
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      Hi Sirio,
      using the latest official Vray5 on Windows11 with the latest R25..
        Maybe it is an error with the latest build or the OS, I'll install the new build later and see if I get that too.
        It should be like this:
          Cool, sounds indeed like mislaid… thanks a lot!
            I think I should have post it under issues... my fault..
            But is there a way to repair it?
              Hello haniel1107,
              I have moved the topic to the Issues section.
              As per the issue itself, I was not able to reproduce this when testing with Cinema4D R25. The version of Cinema4D that I have installed is R25.120 (the latest). Can you please confirm the exact version of Cinema4D and V-Ray that you have installed? If you don't have the latest Cinema4D version, please install it and let me know if that helps. Thanks.
              Aleksandar Kasabov
              chaos.com
                Originally posted by aleksandar.kasabov View Post
                Hello haniel1107,
                Hello Aleksandar,
                I am using the latest nightly build on Windows 11 with C4D R26.15
                The Issue is still there.
                  Hello haniel1107,
                  This issue seems to only affect Cinema4D R26 and is not observed in previous versions. I have reported it to our devs (bug ID: VC4D-1395) and I will let you know once we have updates. Thank you.
                  Aleksandar Kasabov
                  chaos.com
                    Great thank you!!
                      Hello haniel1107,
                      Hi aleksandar.kasabov I saw the update in the today's nightly build. Thanks a lot for fixing this!!
                        Hello haniel1107,
                        That is correct. The issue was fixed and the fix is available in the latest nightly builds. Those can be found here. Thanks.
                        Aleksandar Kasabov
                        chaos.com
