Curvature texture for Node in R26
  • Curvature texture for Node in R26
    I like to use a curvature in a node material, but don't know how to get a bitmap into the sample spread slot.
    Could this be a mistake, or am I doing something wrong?
    Node texture curvature
    Click image for larger version  Name:	Screenshot 2022-06-24 10.08.59.png Views:	0 Size:	162.8 KB ID:	1152117
    Here the classic..
    Click image for larger version  Name:	Screenshot 2022-06-24 10.10.10.png Views:	0 Size:	66.2 KB ID:	1152118
    Using Win11 R26.15 latest available nightly Vray5 build
    Thanks
    Hey haniel1107, the parameter is just not shown in the node view, but it is there and can be connected. You can explicitly show it with the right click context menu, or you can just connect the texture and select the exact port you are connecting to.
    You can also directly select an existing bitmap node if you click the circle for port input in the attribute manager:
    Deyan Hadzhiev
    Developer
    chaos.com
      Hi deyan.hadzhiev , great thank you..!!! This helps a lot!
      I think I should try sometime the right mouse click
        Sometimes you can get away without one
          Hi YunalZobu , this is of course also cool... didn't know this... THANKS!
