Displacement
  • Displacement
    I have not used VRay for a while but have paid for 12 months now so best get stuck in. Where do I add a displacement map on a VRay material (not a node material).
    Use a Vray geometry tag.
    3D Scenes, Shaders and Courses for V-ray and Corona
    NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
    @3drenderandbeyond on social media @3DRnB Twitter
      Hello philip_smith,
      Please check this page, where you can find more information about the Geometry tag and the Displacement workflow, used in V-Ray for Cinema4D. Let us know if you have further questions.
      Aleksandar Kasabov
      chaos.com
        So how would I go about adding displacement to a Chaos Cosmos material? Do I just load the vrmat into the displacement channel as this does not seem to be working when I try it. Thanks in advance.
          You don't apply the displacement to the material but to the desired object. You need to enable the displacement in the Geometry tag and add a texture to it. Let me know if that helps.
          Aleksandar Kasabov
          chaos.com
