Thin film settings - thicknex max greyed out
  • Thin film settings - thicknex max greyed out
    Hi!
    I've been re-watching the webinar for c4d and noticed that in the last stable v-ray 6 version for c4d 2023. The thin film shader Thickness max (nm) parameter is greyed out (locked at 400) both in the classic material and the node material. Am i missing something or is this a bug?
    Hi akos_kiss, the "Thikness Max (nm)" parameter is grayed out because it only has effect when a blending node or shader is connected. Having a blending node or shader actually maps black to the minimum thickness and white to the maximum thickness, allowing you to have a smooth transition. You can easily check out the effect by adding a simple Maxon noise in the "Thickness blend" map.
    Deyan Hadzhiev
    Developer
    chaos.com
      Originally posted by akos_kiss View Post
      Hi!
      Click image for larger version  Name:	image.png Views:	7 Size:	75.4 KB ID:	1164666
      Here you can see an example: https://www.youtube.com/watch?v=n4ua...FBA3G1&index=5 just load a map and you will be able to edit the thickness
      3D Scenes, Shaders and Courses for V-ray and Corona
      NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
      @3drenderandbeyond on social media @3DRnB Twitter
