C4D to Vantage
  • C4D to Vantage
    When does the transfer from Cinema to Vantage finally work so that you can select the same materials in Vantage and then send them by
    one click converts to a different shade?
    Just like in 3Ds Max to Vantage!​
    Hello Wohnraumdesign,
    Could you please elaborate some more on your query? Are you referring to selecting an object/material in Vantage and transferring the selection back to Cinema4D? Please provide more details about this query. Thanks.
    Aleksandar Kasabov
    chaos.com
      In Vantage you can click on an object and then activate the same objects at once and then exchange the materials in Vantage, that works from Max.
      According to Vantage Support, something has to be changed when transferring Cinema 4D objects so that it also works with Cinema 4D!
      Would like to be able to exchange the materials for customer presentations in Vantage and not have to exchange all objects with the same materials individually is unproductive!​
        Would you mind sending us a short video recording of your screen, demonstrating this with V-Ray for 3Ds Max and Vantage, as I still am not sure what is your workflow and what are you trying to achieve? Thank you.
        Aleksandar Kasabov
        chaos.com
          As far as Max is concerned.
          https://www.youtube.com/watch?v=bT7nw4VPnxk
          I made a video about Cinema in Vantage.​
            Thank you for the clarification.
            This issue has been added to an existing report (bug ID: LAV-1007) and I will make sure to let you know once it is fixed. Thanks.
            Aleksandar Kasabov
            chaos.com
              This problem has certainly existed for nine months, it would be great if it were finally fixed!
              At the moment, customer presentations cannot be productively carried out.​
                I understand your frustration. However, currently, I cannot provide any specific timeframe for when this will be fixed. I will let you know as soon as we have any updates. Thank you for your understanding.
                Aleksandar Kasabov
                chaos.com
