Since the last Vray-update (Vray 6 for cinema 4D, hotfix 2 (v6.00.03 from Dec 19 2022) changings in the settings of the vfb won't be safed/remembered. Everytime i close the vfb and re-open it, all changes are lost. How can i fix this?
VFB Settings Problem
Hello h_meier,
Are you referring to the VFB settings (Options menu> VFB settings) or any changes that you are applying to the layers (color corrections, lens effects, etc)? If you are tweaking the VFB settings, you need to save them by clicking on the "Save and close" button at the bottom right corner in order for the changes to take effect.
Please let me know if that helps.Aleksandar Kasabov
chaos.com
Hello aleksandar.kasabov,
I'm referring to changes that i am applying to the layers. As long as the Renderer is set to Standard, everything works fine. But as soon as i change the Renderer to V-Ray, the VFB doesn't save changes in the settings anymore..
- Likes 1
Hello h_meier,
Could you please open a support ticket via our contact form so we can have a look at that? Please make sure to mention this forum thread in the body of the ticket. Thank you.Aleksandar Kasabov
chaos.com
- Likes 1
