Node material bitmap path not updating
This topic has been answered.
  • Node material bitmap path not updating
    We've been using the node based materials more and more since the recent updates but recently noticed an issue with bitmaps.
    When we have a bunch of missing textures i usually go into the project asset inspector and relink the missing bitmaps and assets.
    Unfortunately when i check the bitmap node inside the vray node material the path does not update and after a while the project asset inspector also reverts to the original bad file path.
    Am I missing something or is this a bug?
  • Answer selected by viktor_angelov at 23-02-2023, 06:44 AM.
    Hello akos_kiss,
    I would like to let you know that the bug has been fixed.
    You could download the latest stable build from the link attached and test it yourself: https://nightlies.chaos.com/main#/vray6c4d/stable/6.0
    Regards,​
      Hello akos_kiss,
      Thanks for your report.
      Upon testing, I managed to reproduce the same issue and I have now reported it for fixing (bug ID: VC4D-1696).
      I will let you know once we have any updates on the matter. Thanks.
      Aleksandar Kasabov
      chaos.com
        Hello akos_kiss,
        Regards,​
