Problem with Cosmos materials
This topic has been answered.
  • Problem with Cosmos materials
    Hi
    I'm having problem with some of the materials in the Cosmos library.
    Like the Metal weathered. The problem is that the material does not use the textures that are loaded in the VrayBitmap as you can se in the images.
    I have tried to reload the texture but it does not help, if I load it without the VrayBitmap It works.
    If I create my own material and use VrayBitmap it works just fine?
    Anyone else having this problem?
    Rickard
  • Answer selected by viktor_angelov at 22-02-2023, 11:59 PM.
    Hello Rickard,
    Could you, please, install the latest stable build for V-Ray for Cinema 4D.
    It is expected to work properly with it. Stable build: https://nightlies.chaos.com/main#/vr...e/6.0/20230130
    Regards,
    Viktor​
      Hello Rickard,
      Regards,
      Viktor​
        Hi Viktor
        YES! That did the trick.
        Thanks
