c4d crashes
  • c4d crashes
    Recently C4d crashes when trying to open some vray scenes, and when trying to drag a texture into the vray node editor. I am attaching a link to the video. https://streamable.com/3cu215
    I don't know if it's the fault of recent vray updates or something happened with c4d?
    Hey Makushimu,
    sometimes such crashes may occur because of the cheche files for the node editor. Can you please navigate to your Preferences folder usually located at "C:\Users\User\AppData\Roaming\Maxon\Maxon Cinema 4D XX XXXXXX\description.db". You could also try renaming the Cinema 4D XX XXXXX folder which will reinitialize all the settings from the defaults and then try opening the same crashing scenes again. If the crashing is still there then the issue might be somewhere else and will need more investigation.
    Let us know if this helps.
    Ivan Shaykov
    chaos.com
