Hi All!
I've recently updated to hotfix 3 for c4d 2023 and noticed an issue. When the render mask mode is set to object mode and there are node materials in the scene unfortunately vray ignores the selection and renders all objects that have node material applied.
This only happens when the node materials opacity is used or set to anything other then 100% white (ie: the opacity channel is not used).
I don't know if this affects the other render mask modes or if this was an issue previous builds.
