Multi Matte RE has vignette
This topic has been answered.
  • Multi Matte RE has vignette
    Hello,
    i have a bit of a issue, that occured to me often now and I dont know what is causing it.
    I have my Material IDs in a Multimatte RE. The rendered Multimatte has a vignette and I kinda dont know what is causing it. I attached a example of a multimatte and the RE settings. So if someone can give me a hint on what is happening there, it would be great.
    Thanks in advance
  • Answer selected by aleksandar.kasabov at 30-03-2023, 07:53 AM.
    Hello jonas_schneider,
    Thank you for bringing this to our attention.
    I have logged this in our system (bug ID: VC4D-1763) and I will keep you updated on its progress. Thanks.
      Aleksandar Kasabov
      chaos.com
        Hello,
        I think I ran into the same issue with the white multimatte mode, but only when GPU-rendering (both CUDA and RTX). With CPU, the mask is as it should be, see attached images.
        Using V-Ray 6.10.00 / Cinema 4d 2023.2.0. Is there a solution to this yet (maybe in V-Ray 6.10.01)?
        Thanks in advance.
          Hello fDim Patrick,
          We are aware of this issue and we don't have any updates on it yet. We will let you know as soon as we have any updates on the matter. Thank you for your understanding.
          Aleksandar Kasabov
          chaos.com
