Vray 6 Crashes C4D 2023
  • Vray 6 Crashes C4D 2023
    Been doing some rendering of a scene with mo blur. all was good until I added some objects to the Vray Render Mask Mode then it crashes C4D. Upon opening the scene again, removing the objects from Render Mask Mode and disabling it as default stops the crash. I have the crash report log that I can email support if needed?
    Hello pali_rao,
    Please note that this thread has been moved to the V-Ray for Cinema4D section of the forum.
    As per your issue, does this happen with this specific scene only? Have you experienced similar issues with other scenes as well? Would you mind sharing the scene with all assets for it (go to File> Save Project with Assets) with us so we can have a look?
    Also, please specify the exact version of V-Ray and Cinema4D, your OS, are you rendering with V-Ray or V-Ray GPU? Thank you.
    Aleksandar Kasabov
    chaos.com
