The Vray Object Tag - Exclude Reflection doesn't work with Mesh Light
This topic has been answered.
  • The Vray Object Tag - Exclude Reflection doesn't work with Mesh Light
    Hello,
    if I put a Mesh Light into the exlude reflection Folder in a Vray Object Tag, it is still visible in the reflections.
    Could this be an error? Thanks!
  • Answer selected by aleksandar.kasabov at 18-04-2023, 06:41 AM.
    Hey haniel1107,
    Unfortunately it seems like this isn't an easy fix to be added from the internal builds to the currently available to everyone stable builds of V-Ray 6 (6.00.04). We have to include it with the release of V-Ray 6 Update 1 (6.10). I hope this is Ok for you.
      Hi haniel1107, thanks for your report. It seems this problem was fixed internally, but the fix was not backported to the stable builds. I'll check if this is possible and post an update here afterwards. Even if the backport is not possible, it will be fixed in future major versions. Sorry for any caused inconvenience.
      Deyan Hadzhiev
      Developer
      chaos.com
        Thanks a lot.. !!
          Hello haniel1107,
          Thanks for bringing this to our attention.
          It seems to be a bug and I have reported it to our developers for fixing (bug ID: VC4D-1783). I will let you know if we have any updates. Thanks.
          Aleksandar Kasabov
          chaos.com
            Thank you!
              Hey haniel1107,
              Ivan Shaykov
              chaos.com
                Hello shaio, much appreciated that you inform me. All good, just recognized and... for me all good...
                But sounds like Update 1 is close?
                Thanks!
                  不幸的是,使用球体作为网格光的子级并使用 c4d 图像查看器进行渲染是不可能的,并且仍然需要取消球体的理想渲染。
                  我希望修复此错误
                    Hello painter_li,
                    Please keep in mind that we can only provide support in English. Please rewrite your query in English so we can assist you further. Thanks.
                    Aleksandar Kasabov
                    chaos.com
                      Sorry, it was my mistake
                      What I mean is: unfortunately, using a sphere as a child of a grid light and rendering with a C4D image viewer is not possible, or is it necessary to cancel the ideal rendering of the sphere.
                      I hope to fix this bug​
                        Hi painter_li , by this
                        do you happen to mean having a sphere (with "Render perfect") as a mesh light? E.g. by having this setup:
                        If that is the case - it is expected that the light will not work. By having the sphere as "Render perfect", it is actually rendered as object with no polygons / triangles. And the mesh light works only with objects that have polygons / triangles. So you either need to disable the "Render perfect" option (so the sphere properly generates polygons) or you can use the sphere light, which is specifically designed to render as sphere (and will probably render slightly faster than the mesh light). For now we don't have plans to change this behavior.
                        I hope this does not cause much inconvenience.
                        Deyan Hadzhiev
                        Developer
                        chaos.com
