After vray6.1 update, when interactive rendering in the vfb area is paused and then continued to enable interactive rendering, it will not continue rendering from the previously selected area but render the entire scene together
This topic has been answered.
  • After vray6.1 update, when interactive rendering in the vfb area is paused and then continued to enable interactive rendering, it will not continue rendering from the previously selected area but render the entire scene together
    Is it a bug to enable interactive rendering of regions and then pause and restart to find that the entire image is rendered instead of the region selected last time, which is different from previous 6.0? Because I have tested that the vray restart on max can render in the area selected last time
  • Answer selected by viktor_angelov at 25-05-2023, 11:25 PM.
    Hello 123456_
    I am happy to let you know that we have resolved the issue. The fix can be found in the latest Stable Build: https://nightlies.chaos.com/main#/vray6c4d/stable/6.1
      Hello 123456_
      Thank you very much for your time and efforts to provide the necessary information to replicate the issue on our side. It is classified as a bug (VC4D-1841) and escalated to the Development team for further inspection and resolution.
        Hello 123456_
          Originally posted by viktor_angelov View Post
          Hello 123456_
          Yes, the software is working properly now. Thank you for your notification
            Hello 123456_
            I found that after enabling the Test resolution feature, the same issue occurred again,I recorded a problem video
              Thank you for sharing, 123456_ We have reproduced the issue. You will be contacted if the matter is further developed.
