Can I have an engineering file for heat haze
  • Can I have an engineering file for heat haze
    Anyway, I can't use V-Ray VolumeGrid to achieve heat haze effect on c4d. Can you give me a successful engineering file with vdb files
    I tested today's updates and found that although they can produce a heat haze effect, modifying any parameters during the interactive rendering process will cause the entire software to freeze. I recorded a video to demonstrate。And rendering the animation sequence frames of hot fog can also cause the software to freeze
      Hello 123456_
      Thank you for reporting this. We have reproduced the issue and are currently investigating. We will contact you if it's further developed.
