Why can't the parallel projection of the camera be displayed when I add a camera label?
This topic has been answered.
  • Why can't the parallel projection of the camera be displayed when I add a camera label?
    I recorded a video to illustrate the issue
  • Answer selected by deyan.hadzhiev at 13-09-2023, 01:17 AM.
    Hi 123456_, the physical camera tag can be used to render parallel Cinema 4D camera. Unfortunately, it currently requires some additional manual setup of other parameters (see example below). To be precise, the Focus Distance of the Camera object must be set to 1, and the Film Gate and Focal Length of the Physical Camera Tag must be set to 1. This manual step is something we may improve in the future, but for now it is necessary.
      Deyan Hadzhiev
      Developer
      chaos.com
        Thank you very much for your answer
          Hello 123456_,
          Please note that with the release of the latest update of V-Ray for Cinema4D the setting of the Parallel camera has been improved. You can find more information about the update here. Thanks!
          Aleksandar Kasabov
          chaos.com
