Hi all,
I'm having an issue with the V-Ray Image Output settings. For some reason, it's not including the frame number in the filename of the output files. This means that when I'm rendering an animation, it's just repeatedly overwriting the same file rather than saving it as the next one in the sequence.
I've attached my V-Ray Output Settings. I've also tried adding in _#### at the end of the filename section, but this just added hashes in the output rather than frame numbers.
Can anyone advise me what I'm doing wrong? I'm sure this must be an easy thing to fix.
Cheers
Jeff
Cheers
Jeff
