Big issues in 6.2 on GPU
  • Big issues in 6.2 on GPU
    I'm a bit shocked some of this stuff was missed as its very apparent. Lack of testing?
    Anyways, Noise seems to have some pretty awful issues on GPU. Both noise nodes do this. CPU does not have this issue nor does 6.1 as far as I know.
    Here is the same on CPU
    Next up when I turn on lightpass mode for interactive in GPU... it refreshes every second, forever even when you aren't doing anything just constantly starts and stops building light cache.
    Would be nice to see a hotfix on these items.​​
    The first image seems pretty odd, because this behaviour I would expect when I use very small values on the TrIplanar node, simply because it tiles the noise on a small value. I am more surprised that the CPU rendering doesnt have the tiling
      Hey, Seth, Jonas,
      Thank you for the comments and reports. I really appreciate it. seth_richardson Seth, I will open a ticket for future implementation of Maxon Noise to work with the Triplanar map on GPU. As for the second point could please help me with scene file to reproduce the problem
      Cheers,
      Boyan Nalchadjiiski | QA Engineer @ Chaos |
      E-mail: boyan.nalchadjiiski@chaos.com
        Originally posted by boyan View Post
        Hey, Seth, Jonas,
        Cheers,
        This issue with the constantly refreshing vfb is being caused by the existence of redshift materials, regardless of if they are applied or not. Deleting the material made light cache on interactive rending behave normally.
          seth_richardson
          Seth, could please try UVW Channel node with Noise maps and triplanar, when using node materials?
          cheers,
