The larger the angle between splines and the camera, the blurrier the image, and the farther away from the camera, the blurrier it becomes
  • The larger the angle between splines and the camera, the blurrier the image, and the farther away from the camera, the blurrier it becomes
    To be honest, I'm not sure if this is an error, but it's definitely causing me some trouble. I noticed this while testing cartoon rendering.
    Use version:https://nightlies.chaos.com/main#/vr...e/6.2/20240105
    Hello qingyuan_pang Thank you for sharing! At first glance this seems normal. I would increase the resolution and give it another try. Please, let me know if this resolve the situation.
      I tested increasing the resolution to no avail
        Are you able to reproduce it on a simple scene as well?
        Please share the scene with us so we can investigate further. You can do that here or by Submitting a Request to our system: Submit a request
          Has been sent
            Hello qingyuan_pang Thank you for the scene! This might be caused by an issue that's been logged into our system [VC4D-2155] We will contact you if the matter is further developed.
            Meanwhile, there are two workaround that can be done:
            1. Increase the Start Width of the VrayRenderableSpline: http://ftp.chaosgroup.com/support/sc...6_09-42-41.mp4
            2. Increase the Width and Height of the Output: http://ftp.chaosgroup.com/support/sc...6_09-45-06.mp4
