osl node material is not available,texosl is also not available
vray 6.2 osl node material is not available
Hi qingyuan_pang Thank you for contacting us! We tested the V-Ray OSLMaterial and it works as expected. Could you please provide us your .osl file so we can investigate further?
Originally posted by viktor_angelov View PostHi qingyuan_pang Thank you for contacting us! We tested the V-Ray OSLMaterial and it works as expected. Could you please provide us your .osl file so we can investigate further?
Originally posted by viktor_angelov View PostI understand that. We have tested both and they work as expected at the moment. That is why it would be very useful if you could share the osl file that you are using so we can check it as well.
Hello qingyuan_pang Thank you for your patience! We are currently working on improving V-Ray OSL Node materials. At this point I would recommend you to use the Standard V-Ray OSL Materials.
When using the Standard materials, make sure to use the Closure Output dropdown menu when necessary: http://ftp.chaosgroup.com/support/sc...5_11-09-12.jpg
This is due to the different type of OSL file.
