Hi, if you render an animation and set "RGB Channel Output" to "Only RGB" in the "Common"-settings, vray overwrites every rendered frame when saving. So in the morning you got only one lonely image instead of the whole animation.
If you render an animation and set "RGB Channel Output" to "Only RGB" in the "Common"-settings, vray overwrites every rendered frame when saving
Hello steilvorlage.de,
This is a known issue which has previously been discussed here. It is logged in our internal system (bug ID: VC4D-1842) and we will let you know if we have further development on the matter. Thank you.Aleksandar Kasabov
chaos.com
- Likes 1
