Hi marco_zanella, this warning may have different sources of the problem (from something wrong with the scene to hardware problems when shading materials). So it would be best if you can share more details to allow us to help you better:
1. Please share the exact versions of Cinema 4D and V-Ray for Cinema 4D. Also sharing your OS version and CPU would help more.
2. If you can reproduce this with a simple scene you can share - it may be best.
3. It would help if you can share your original scene by opening a support ticket.
Although it may seem harmless, this warning can lead to wrong / invalid render results, even if not clearly visible.
Hello marco_zanella I would like to let you know that the issue has been logged in our system [VC4D-2180] We will let you know when it's been implemented and ready to use.
