Change camera offset in python does not works
  • Change camera offset in python does not works
    Hello,
    In order to manage tile rendering, i was used to (with vray 3.7) use command line listener method, with python code changing camera focal and cam offset X and cam offset Y. Actually i can change camera focal, but i did not found any way to change camera offset, it behaves like both camera offset (X + Y) are reset to "0". My camera does have a VRay physical camera tag
    I also noticed that Vray can not take into account camera offset when this one does not have a Vray Physical camera.. weird no?
    Regards,
    Well, i just figured out that using "pinhole" mode in the render settings override for the camera, force VRay to ignore offsets parameters (and others not very conventional i suppose...) So i let my cam as "standard" one, and it seems there is no merging problem with the rendered tiles.
      Hello f2b It seems like you have managed to find an answer to your questions. Thank you for sharing! I am sure other users will find it useful.
