Vray ies light adjustment light size useless
  • Vray ies light adjustment light size useless
    As demonstrated in the video, scaling the lights doesn't work. I can only achieve the goal by manually modifying the values, but it's troublesome. Is this a bug?
    Hello 123456_ I've informed the Cinema 4D development team about this, and I will update you on any progress made on the subject. In the meantime, you can try using the following method to rescale your V-Ray IES Lights:
    1. Change from Model Mode to Object Mode.
    2. Rescale the light as you see fit.
    Example:
    Daniel Kapsazov | chaos.com
      Example:
      Thank you for informing me
