Adding a Colorizer shader to vray Dome Light can cause the scene to turn black
  • Adding a Colorizer shader to vray Dome Light can cause the scene to turn black
    This was not like this in previous versions, I recorded a problem video Click image for larger version
ID:	1209535 Click image for larger version
    Nihao,
    First of all, thank you for your reports!
    It seems this setup won't work because it is not implemented. However, you can replace the colorize with a "TexAcolor"​ texture and used it as Production, this will give you a lot more power.
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      Originally posted by boyan View Post
      Nihao,
      This should be a bug because I can use this shader normally with this version of Vray Click image for larger version
        Nihao,
        Thank you for the response. It is my fault; the ticket is already in our system, as indeed this is a regression.
        Cheers
