Adjusting a Node VRay Material doesn't refresh in the VFB
I have to stop and start the VFB every time I want to see updates I make within the Node Editor (e.g., simple diffuse color changes). With the regular shaders it's instant. Tell me what I am doing wrong, plz
OK. I tried it again without my custom default scene and it seems to work. You would think that it wouldn't load that scene since I'm using the new prefs like you suggested. But now I reenable my old prefs w/o that custom default scene and I have that problem again. It's looking like I going to have to rebuild my preferences again.
Hi t.j.cianciolo, thanks to your screenshot I believe I can hint why you experience this problem. I'll not dig into details (and we are aware of this problem, but it is not trivial to fix), but it boils down to having the VFB docked in the same panel as your viewport. In other words - in order to avoid problems with the VFB interactive not updating, you must have at least one viewport panel active (by active it is sufficient to be selected and visible).
If you don't need the VFB specific controls (layers, history, etc) but only want interactive render, you can try the Viewport Interactive rendering, which does not have this problem. You can read more information about it here.
