Ambient Occlusion - Dirt Shader - need help
  • Ambient Occlusion - Dirt Shader - need help
    Hello,
    I try to generate an Ambient Oclusion Channel but I alway get a white Layer as result.
    I've added a Render Element "Extra Tex"
    Then I added in Texture the VRayDirt-Shader.
    But the result, when rendering, is only a white Layer.
    Question:
    How do I generate a Ambient Occlusion Layer?
    Regards Ronald
    Hello Kissling Thank you for reaching out to us! I've assigned your ticket to myself, and I will provide you with an answer through our ticketing system.
    Daniel Kapsazov | chaos.com
      Originally posted by Kissling View Post
      Hello,
      Question:
      Regards Ronald
      It looks like a GPU limitation, works fine if you use Vray CPU.
      I've not used dirt in extratex in a while, but in the past "consider for antialiasing" had to be activated.
      3D Scenes, Shaders and Courses for V-ray and Corona
      NEW V-Ray 5 Metal Shader Bundle (C4D/Max): https://www.3dtutorialandbeyond.com/...ders-cinema4d/
      @3drenderandbeyond on social media @3DRnB Twitter
