Hi alfonso_pennacchio, When using the Opacity slider on the Denoiser layer, the changes are only reflected in the RGB Color Render Element. If you want to see the same effect in the effectsResult RE, you can do the following:
Switch the Source Layer to Composite mode. - Screenshot
