VRay is unable to read the radius and direction attributes of the new particle emitter for C4D
  • VRay is unable to read the radius and direction attributes of the new particle emitter for C4D
    I uploaded the problem file Click image for larger version
    Hello 123456_, thank you for reporting this. This behavior has been logged on our end under request number (VC4D-2431), and once the change has been implemented, I will inform you here.
    Daniel Kapsazov | chaos.com
      ​Thank you for your reply
        I hope this issue can be fixed soon, as the particle rendering has a significant impact
          Ni hao, 123456,
          Thank you for your patience. The fix is already in the stable build, so you can download and use it. Please let me know if you have any issues relative to this item.
          Cheers,
          Boyan Nalchadjiiski | QA Engineer @ Chaos |
          E-mail: boyan.nalchadjiiski@chaos.com
            Originally posted by boyan View Post
            Ni hao, 123456,
            Cheers,
            Yes, thank you for informing me. It's running well now
