Failed to init Texture RGB Color Space conversion from lin_srgb to scene-linear Rec.709-sRGB
  • Failed to init Texture RGB Color Space conversion from lin_srgb to scene-linear Rec.709-sRGB
    When opening a previously created project, it fails to render and gives the message Failed to init Texture RGB Color Space conversion from lin_srgb to scene-linear Rec.709-sRGB
    Hello, qingyuan_pang
    Thank you for the report! Could you please check : 1: Open the VFB and check the OCIO file location; 2/Next, please confirm that OCIO files exist in your location.
    Cheers,
    Boyan Nalchadjiiski | QA Engineer @ Chaos |
    E-mail: boyan.nalchadjiiski@chaos.com
      Cheers,
      No aces used
        Cheers,
        I reset the color space, but my lighting is not working
          Hey,
          Could you please share with us what you have in that scene? Please check if you have texture OCIO in rectangular light. What is the Cinema 4D release? In case of 2025 release, switch to sRGB and try it once. Most likely I miss something in the picture, but not sure what is that.
          Cheers,
