Rendering with multiple errors
  • Rendering with multiple errors
    Hi all,
    I've been experiencing several errors when rendering for several days, I've removed all plugins other than v-ray and it continues to give errors.​
    Errors appear in any project, i need help to solve this problem​.
    Thank you!
ID:	1220966Click image for larger version
ID:	1220967​​Click image for larger version
    Hello craveiro, I’d be happy to assist you with this issue. To better understand the situation, could you please provide the following information:
    • Does this behavior occur when rendering with Cinema 4D’s native render engine, or is it exclusive to V-Ray?
    • If it only happens with V-Ray, does the issue occur immediately after starting the render?
    • You mentioned uninstalling all plugins; have you also tried uninstalling and reinstalling V-Ray?
    If you’ve already tried reinstalling V-Ray and the issue persists, could you please share the _BugReport.zip and minidump.dmp files? These can be found in the following directory:
    /Users/username/AppData/Roaming/MAXON/Maxon Cinema 4D <version>/_bugreports
    Looking forward to your response.​
    Daniel Kapsazov | chaos.com
      Hello daniel.kapsazov , Thanks for your help
      ​[*]Does this behavior occur when rendering with Cinema 4D’s native render engine, or is it exclusive to V-Ray? It is exclusive to V-Ray.[*]If it only happens with V-Ray, does the issue occur immediately after starting the render? Sometimes it is immediate, other times it occurs after a few seconds.​[*]You mentioned uninstalling all plugins; have you also tried uninstalling and reinstalling V-Ray? Not yet[/LIST]If you’ve already tried reinstalling V-Ray and the issue persists, could you please share the _BugReport.zip and minidump.dmp files? These can be found in the following directory:
      Looking forward to your response.​[/QUOTE]
