VRay cannot modify the size of IES' lights
  • VRay cannot modify the size of IES' lights
ID:	1221084 Click image for larger version
ID:	1221085 Just like in the picture, I increased the size of the light, but the effect did not change. I uploaded a demonstration video and project of the problem
    Hello 123456_
    If you are using IES lights, the scene should be up to scale. In that case, there shouldn't be a need to increase the size of the light, as the file comes from the manufacturer of the specific light with predefined intensity, direction, size, etc.
    Тhere is a simple workaround if you want to increase it. Select the Light, go to the Attributes menu and only adjust the X and Y parameters. This should do it:
    Could you, please, let me know why would you want to increase the IES lights? ​
      Originally posted by viktor_angelov View Post
      Hello 123456_
      Thank you for your reply. I understand now
