V-RayPhysicalCamera's stereoscopic rendering does not work correctly
  • V-RayPhysicalCamera's stereoscopic rendering does not work correctly
    When enabling stereoscopic rendering for V-RayPhysicalCamera, the first zero frame is fine, but subsequent frames do not render stereoscopically correctly.
    Attached sample scene and rendering sequence
    Confirmed with CINEMA 4D 2025.0.2 with V-Ray 6.20.05​
    OakCorp Japan - Yuji Yamauchi
    oakcorp.net
    v-ray.jp
    Chaos team doesn't test anyone?
    oakcorp.net
    v-ray.jp
      Hello flat, Apologies for the inconvenience this has caused on your side. The issue has already been logged on our end ( VC4D-2628 )I will personally take ownership of following up with you once a resolution has been implemented.
      Regarding your second comment, I can assure you that all products are tested extensively before each release. However, due to the sheer number of features and resolved bugs being tested, there is always a possibility for something to be missed.
      Thank you for your understanding!​
      Daniel Kapsazov | chaos.com
        Thanks for the report, which is a known issue.
        I hope it gets fixed soon.​
        oakcorp.net
        v-ray.jp
          こんにちは、レポートありがとうございます。
          (Konnichiwa, repōto arigatō gozaimasu.)​
          It appears that there is an issue when saving animation from Cinema4D, but as a workaround, you can use standalone, which works.
          Cheers,
          Boyan Nalchadjiiski | QA Engineer @ Chaos |
          E-mail: boyan.nalchadjiiski@chaos.com
            Hi, Boyan sann
            In the moment I can confirm that it works correctly when rendering in standalone.
            Thanks for the advice.​
            oakcorp.net
            v-ray.jp
