I am not able to see my projects in the viewport
  • I am not able to see my projects in the viewport
    Hello, I have a huge issue.
    I have updated to version 7 my very, but now I am not able to work on my old projects as nothing will be displayed in the viewport.. Geometry is there in the object manager, but nothing in the viewport.. plus I am not able to zoom pan, rotate, or create any primitives or new geometry.. basically I can do nothing....if I switch to render engine standard, all are back to normal...problemm is all my files are done with vray///​
    Hey marco_zanella, can you try if the problem is reproducible in a new scene with V-Ray? There is a known issue when the Bump node is used in a node material, and it will be fixed very soon.
    Deyan Hadzhiev
    Developer
    chaos.com
      i have tried with an enterly new scene and no problems found..all ok..i have also saved and re open the new scene but all is perfect...see attachments
      the problem with old file persist...what should i do? i would like not to roll back if possible, buit i have to work on 1 week old projects...
        i have tried the bump, and yes all freeze...
          We will have the fix for this problem available in our nightly builds tonight, so tomorrow you should be able to download a build with the fix.
          Deyan Hadzhiev
          Developer
          chaos.com
            cool...thank you so much..will let you know if all ok
            Best
              Good morning, any news about the fix?
                Hello marco_zanella I am glad to let you know that the fix has been implemented in the latest stable V-Ray 7 for Cinema 4D build. You can find it here: https://nightlies.chaos.com/main#/vrayc4d7/stable
                If the page is empty, please, log out ( top right corner ) and then log in again. If it's still empty, let me know.
                  i am sorry but i cannot see it...
                    Could you please give me the email address that you have used to register? It should be the same that you used to purchase the software.
                      zan3lla.marco@gmail.com
                        I have opened a ticket on your behalf with request to grant you access. The ticket is number 335188. They should contact you once it's done.
                          thank you so much
                            Guys...what is happening here.....i have understand that is not my day, but this is really bizzare.....
                              Dear Marco, Hello.
                              Don't worry, everything is under control.
                              We are trying to get you the access for stable nightlies.
                              You will be contacted soon.
                              3D Support (AEC,HOU,C4D) Team Lead | contact us
